kevin b
Annoying new text anchors in AC13
Anyone know if there is a way to turn of the new "feature" that shows the anchor point of text blocks and leaders as a big bold "+" without turning off the handles? Or a way to change them to be less annoying (ie less bold, diff color) I can't find anything about controling them. I can't even find anything describing them as a new "feature."
Anyone else out there like them? Hate them?
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
Intel Core i7 -8700 @ 3.2 GHz~ 16 GB ram
22 Replies 22
I like the idea of visually marking the anchor point especially for text, but rather than a big fat '+', a better way would have been to just thicken up the chosen corner handle by an extra pixel. In my opinion the + is a bit over the top and quite distracting.
It might even be worth extending the same idea to other tools with anchor points, like Objects, Figures and Drawings. I know you can see a representation of the anchor point in the info box, but it would be useful as an visual reminder before the element is selected.
kevin b
I agree I like the idea of it, I just don't like the execution, it should be more user controllable.
kevin s burns, AIA
massachusetts, usa
Windows 10
kevin wrote:
...it should be more user controllable.
I'd rather GS got it right in the first place, then you wouldn't need to fiddle with it!
David Maudlin
And not always consistent, see example image below.
A better approach might have been a user controlled color (like other selection options in the Work Environment) to highlight the anchor point.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I checked this and I don't think there is any such setting.
Personally I think if there was, then there would come some other request to be able to set the size, shape and color of the corner markings then something else then something else, so it may lead to a never ending story. Personal opinion of mine.
But as I looked into the Text Settings Dialog, I found something interesting.
Did you guys notice the new "Always Readable" checkbox?
It will always rotate the Textblock so it is never upside down.
Is there a setting somewhere to get rid of the + you are seeing at the corner of the text box in AC13? I know there is a setting in "View" "On screen view options" and "text handles" but I don't mind those, i just don't like the darn plus sign...
Ahhh! Me no like these!
Eduardo Rolon
At least they don't print
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Keep up Steven! We've had a good moan about this already!
http://archicad-talk.graphisoft.com/viewtopic.php?p=154747
