2008-12-15
11:42 AM
2023-05-23
04:58 PM
Rubia Torres
2008-12-15 12:43 PM
2008-12-15 02:05 PM
2008-12-15 02:50 PM
2008-12-15 03:20 PM
2008-12-15 03:29 PM
David wrote:The good thing: you do not need AC8, as the 9 can write back to 8.1, 8.0, 7, 6.5 & 6.0 ...
kliment:
It should be possible, via AC 12 to 11, 11 to 10, etc. (There is an acknowledged bug saving from 12 to 11.) This means all versions from 12 to 7 would need to be installed.
2008-12-15 07:38 PM
kliment wrote:You will not even get the geometry. No 'new' features will export to versions incapable of interpreting them.
... And I need all the LibParts and Complex Profiles from AC12. I do not expect them to work as complex profiles, I want only the geometry!
2008-12-15 10:02 PM
kliment wrote:AC12 to AC7 sounds like a nightmare. Even just to get the geometry would be tedious and error prone with losses assured in model quality and integrity.
This is what I found too, David!And I need all the LibParts and Complex Profiles from AC12. I do not expect them to work as complex profiles, I want only the geometry!
There are some nice rendering techniques I miss from AC7!
2008-12-15 10:45 PM
David wrote:Can you tell me more about this? I need to save in AC11 for someone coming up.
kliment:
2008-12-15 10:50 PM
Rick wrote:See this thread:David wrote:Can you tell me more about this? I need to save in AC11 for someone coming up.
kliment:
thanks
