Any ideas how to backsave from 12 to 7?
Has anyone tried to downsave a project from AC12 to AC7? Is it possible at all?
I think it should be easier with save as a binary object, but still haven't succeeded!
Any ideas and experience will be greatly appreciated!
10 Replies 10
rocorona
IFC?
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
I doubt AC7 knows what IFC is! 😉
David Maudlin
kliment:
It should be possible, via AC 12 to 11, 11 to 10, etc. (There is an acknowledged bug saving from 12 to 11.) This means all versions from 12 to 7 would need to be installed. The any library parts that are not 7 will not work with the 7 file. So it should be possible, but not convenient. Why do you want a file in a format that dates to 2002?
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
This is what I found too, David! And I need all the LibParts and Complex Profiles from AC12. I do not expect them to work as complex profiles, I want only the geometry!
There are some nice rendering techniques I miss from AC7!
rocorona
David wrote:
kliment:
David
The good thing: you do not need AC8, as the 9 can write back to 8.1, 8.0, 7, 6.5 & 6.0 ...
_________________
--Roberto Corona--
www.archiradar.com
_________________
_________________
kliment wrote:
... And I need all the LibParts and Complex Profiles from AC12. I do not expect them to work as complex profiles, I want only the geometry!
You will not even get the geometry. No 'new' features will export to versions incapable of interpreting them.
So, if you must have the complex profiles - you will have to convert every complex profiled element into an object. But, then I don't think the objects from 12 can be down-converted into an earlier version of GDL automatically...?
I've never tried to go backwards...so don't know what tricks might work.
Karl
AC12 to AC7 sounds like a nightmare. Even just to get the geometry would be tedious and error prone with losses assured in model quality and integrity.
What can 7 do that 12 can't? All the old rendering engines are still intact.
Rick Thompson
David wrote:
kliment:
David
Can you tell me more about this? I need to save in AC11 for someone coming up.
thanks
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
Rick wrote:
David wrote:
kliment:
David
thanks
See this thread:
http://archicad-talk.graphisoft.com/viewtopic.php?t=26720
two workarounds given, pending the next hotfix.
Karl
