Thomas Nymann
Any tip as how to create multiple slabs in one go?
Hi there.
I´m wondering whether theres a trick to create multiple Slabs, in 1 or at least a few actions... Lets say you have a .dwg showing a site with multplie (+50) building contours.
I those should be raises as Slabs (or morphs) - Do we then have a a neat trick to do it faster than manually using Magic Wand on each of the contours?
Kind regards
Thomas
Operating system used: Windows 27 Build 5001
ASUS ROG I9 12900H 🙂 - RTX 3080ti (16GB) - 32 GB RAM - Ryzen 7 1700X 3,8GHz. - GTX 1080ti 11 GB- 16GB RAM
AC 13 +
11 Replies 11
Yves
It works from archicad 23 provided that the goodies are installed and the graphisoft accessory library is loaded
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
kmitotk
I've never tried in a large scale but this should work. See attached. The end result will be morphs.
Kei Mito
MITO architecture + design
Architect | Graphisoft Certified BIM Manager
ArchiCAD 29 JPN/USA/INT | Windows 11
