Any way to make a wall visible in another story?
I'm doing a project on a steeply sloping site, which slopes up 4 stories, and for the site plan, would site walls & features from 4 stories to show up on the site plan.
Any way to do this aside from putting all of them on the same story?
Thanks,
3 Replies 3
1. solution...... If that site walls are without doors and windows, use BEAMS instead of walls
and set the visibility to "All Stories".
2. solution...... Show all wanted elements and open them in 3D window. Then select view from the TOP.
David Maudlin
svenl:
You should look at a combination of the Floor Plan Display options for Walls (Floor Plan and Section > Floor Plan Display) and the Floor Plan Cut Plane, which allows walls to show on more than their home story.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks for the replies. 2 very good solutions. I suppose you could make the site walls with a mesh as well, if you wanted to slope the top.
