Append Composites Trouble
In the Attribute Manager, I open the composite attribute file saved from another project. I select the composites I need, and Append them to the current Project.
When I open the composites window, the skin dimensions are correct, but all the fill patterns have changed to "Common Brick".
Can anyone explain this?
8 REPLIES 8
Aaron Bourgoin
We can't edit index numbers which are the critial components of all attributes. If you need a fill whose index differs from file to file then you must overwrite the fill and then decide whether you are overwriting or appending the composite.
Index Number Editing is a very contentious issue here.
Think Like a Spec Writer
MacBook M4Pro
AC4.55 through 29 / AC29.0.2 USA
Rhino 8.27 Mac
MacOS Tahoe 26.2
One file has a DWG xref. Could this alter my fill index numbering?
I've checked the index numbering and fill assignments for all fills used in the project, and they all match; file to file. I used overwrite to transfer all fills from the source file to the host file. Next I exported composites and used 'overwrite' to transfer composites to the host file.
The problem still perists after this.
TomWaltz
This might sound dumb, but I tend to have better luck placing the composite I want the copy/pasting it into the second file.
Tom Waltz
interesting....
I think you mean the lack of index number editing
well, when all else fails....
close and reopen AC?
seems to have done the trick.
TomWaltz
LINZ wrote:
interesting....
Usually everything except custom materials (bit map textures) come across this way.
Tom Waltz
