2004-08-13
12:38 AM
2023-05-26
12:36 PM
Rubia Torres
2004-08-13 01:44 AM
Tom wrote:There is a button on the beam's pet palette for placing a hole. Beam selected, non-arrow tool active, click on the ref line of the beam. It brings up a dialog where you can put in the size, shape, and position.
How can I put a hole in a beam? Is it possible?
Also, I draw an arc in a S/E. Where in the heck can I find out what the radius is?Radial dimension tool is not working for you? And you can place the origin at the center, rest on the arc, and read the 'r' box. If you are trying to get the radius of an arc'd element in elevation, such as an arch, it won't work, since the curve is made of segments. You'll have to draw an an arc over the curve and take the radius of that.
2004-08-13 02:31 AM
2004-08-13 06:12 AM
Tom wrote:Clickin the arc with the arrow tool in the Mercedes shape will give you the option to change the R; the R field reads current value, and you can type n the desired value, therefore changing the R of the arc.
I was looking for a place where I could see the radius and change it all at the same time.
2004-08-13 01:51 PM
2004-08-13 02:15 PM
2004-08-13 02:18 PM
2004-08-13 08:06 PM
Tom wrote:You mean in the elevation where you see the beam?
However, am unable to dim the radius of the arc in S/E using the radial dim. Any suggestions there?
2004-08-13 10:04 PM
