Arched Window Headers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2011-02-08
12:18 AM
2023-05-26
02:33 PM
Rubia Torres
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-08 02:43 PM
Welcome to the forum!
Can you attach a screenshot of the problem? Maybe someone will have a solution once they see it. Also it would be very helpful to note what operating system you are on, what version of ArchiCAD are you using, and exactly which window is displaying the problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-20 11:03 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-20 05:23 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-22 02:06 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-23 04:06 AM
It looks like there needs to be a new adjustable arched top window where the arch extends right through to the inside of the wall, and the infill piece forms part of the frame and is the same thickness. I've attached a real-life example I've encountered in an old farmhouse recently. I presume this is similar to the type of construction you require.
I think it would also be useful to be able to adjust the radius of the top curve on the other arch topped windows too. Not all are semi-circular in reality.
One way you could work around the limitation at the moment is to cut away the incorrect piece of wall above the window with a hidden complex profiled beam SEOed away from the wall, and then manually add in another piece of shaped beam to infill the gap again with the correct materials applied.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-23 04:14 AM
Hope that helps for the moment. Let's hope they introduce a window that can do this automatically soon! I wouldn't have thought it was a massive job for GS to slightly adapt the wallhole, as the 'W Arched Top Opening 14' window can do this shape already just without the frame.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-23 09:48 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-23 08:06 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-02-23 11:35 PM
