ā2016-03-28
09:00 PM
ā2023-05-24
08:41 AM
Rubia Torres
ā2016-03-28 09:01 PM
ā2016-03-28 10:17 PM
ā2016-03-29 02:29 PM
ā2016-03-29 02:35 PM
ā2016-03-29 03:29 PM
ā2016-03-29 05:51 PM
mbeam wrote:You can increase window resolution for smoothness.
I don't like the way the door/window openings look myself so I would use an SEO so you get an smooth looking arch and not a segmented arch. I would use a shell, curve it to the arch you want, and then do and SEO subtraction with downward extrusion.
I might also do a complex profile SEO. Just go to that elevation, draw the arch in lines how you want it, cut and paste into a complex profile, extrude, place the profile and do the SEO. What's nice about this way of doing this is you can swap out complex profiles on the fly and it makes it easy to show it this way or that way with profile management.
ā2016-03-29 06:32 PM
ā2016-03-30 02:40 PM
mbeam wrote:Window Settings > Opening Settings > Window Opening... > Curve Resolution (similar setting for Door also).Rammstein wrote:How do you increase the resolution?
