Arched opening problems
I still can't figure it out. Anytime I place an arched opening, the opening width lines do not appear. But every thing is fine in an empty opening. See attached. Any Ideas? I have looked for every setting. Maybe I'm missing something.
Jim
Jim,
In the parameters list for the arch opening window,
right at the top, do you see a parameter called
Wall contours (0-none, 1-full, 2-side, 3-length) ?
If you do set it to 2.
Peter Devlin
How the hell did I miss That! Thank you Peter.
Jim
