2stories height window
Hello everybody,
I would like to ask something rather simple.
How can I create a 2stories height window? Until now I created a 2stories height wall on the ground floor, placed a window and the 3D model looked fine. The problem is that I could not see that wall & the window on the 1st floor plan view.
Thank you in advanced
Fotis K.
Thomas Holm
Change the wall to show as Cut Only. Check the cutplane settings to allow it to be seen in both stories.
The method Thomas wrote is new to 10 so if you are on an earlier version you will need to use some work-arounds..
