ArchiCAD 10 to 11 problems
I have a project plan that I created using ArchiCAD 10's library on another computer. The computer I am using now has ArchiCAD 11, but does not have the ArchiCAD 10 library. As such, I can't work on my project on my current computer, because the library is not available.
Is there any way I can download the ArchiCAD 10 library or upgrade my project into ArchiCAD 11's library?
Quoting Djordje from HERE
"If you use 10 project in 11, unless you want to re-link all the lib parts, you should load the Subset 10 library - you can find it at the update Web page."
... but I found it in the Goodies section (go to Help> Archicad11 Goodies)
Djordje
You are upside down, mate ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
