ā2009-11-24 06:03 PM
ā2009-12-08 01:07 AM
ā2009-12-09 05:55 PM
Ben wrote:Ben (or anyone else), care to share how you were able to resolve this issue? Since the next post says you got it. I am just now dealing with this issue with our BIM Server located on a 64-bit Windows 7 server. It's located on the C: of the server but still says not found even after I locate the right directory being C:\Program Files\Graphisoft\BIM Server\TeamworkServer.
Hi Greg
I am having trouble updating my BIM Server. Its installed on a separate drive (not on C:), the hotfix cannot find it, but even if i redirect to the installed directory E:\Program Files\Graphisoft\BIM Server\TeamworkServer the installer cannot find the BIM server. This is rather urgent as I have already updated a few of the client machines....
Thanks
ā2009-12-09 09:53 PM
ā2009-12-09 11:38 PM
ksymons19 wrote:We had been having trouble with the box the BIM server is on, I just had to reboot and it worked. I dont think that machine had been rebooted since the BIM server was first installed on it.
Thanks!
ā2010-02-19 02:56 PM
gkmethy wrote:Attached is my ArchiCAD build information. Can anyone tell me if I need to update? It keeps on saying I'm not up to date, but when I download and go to install, it cannot find ArchiCAD for some reason. From what I can tell, I already have installed this update previously (one of the few countries to get it early), and the message telling me I'm not up to date is erroneous...
Dear Talkers,
ArchiCAD 13 Hotfix-2 (build3235) is now available. The name is Hotfix-2, but this is the first hotfix generally available.
ā2010-02-19 07:33 PM
ā2010-02-19 08:42 PM
ā2010-02-19 08:45 PM
ā2010-02-19 11:34 PM
Karl wrote:Looks like you added "13" to the "Archicad" application (so you could differentiate it from other versions in the doc??). Rename it "Archicad" and it should work.
You must have modified something about your AC program folder, whether renaming the application/exe, moving it somewhere else...or?
ā2010-02-22 02:23 PM
