ArchiCAD 14 - Text Bug... cursor jumps!
Does anyone out there have this problem? I know my office does! When editing text, the cursor will jump while in mid-type. Any advice or tips on how to correct this problem. I've downloaded the most recent HotFix but no luck.
28 REPLIES 28
vfrontiers
But I think we do have the answer...
It's a bug and it won't get better until GS fixes it...
I didn't say it was good answer!
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
Haha you are right. Does Graphisoft read these posts on a regular basis? Hope so!
Don't rely on ArchiCAD Talk to get the word to GS about this bug. They do read it but there is no guarantee the info will get to the right parties in a timely fashion. To file a bug report either contact your reseller or regional office and/or launch the bug reporter program (in your ArchiCAD folder) and send it direct ton GS.
Achille Pavlidis
I'm definitively facing the same problem!
Very annoying!
Mac OS 26.1 | AC 29.0.2 INT 3200 FULL
Hi guys,
Can someone post precise steps that reproduce this problem? I've tried the insert-in-middle-of-word-wrap-block and the other things mentioned here, and cannot see the issue on my Mac.
Will report the bug once we have steps that allow the engineers to reproduce the issue.
Thanks,
PS Hi Duane - maybe can you start a new thread with your separate Navigator issue and/or report it to tech support with a file they can use to reproduce it.
vfrontiers
Karl,
The text one is intermittent... It happens with no apparent rhyme or reason. I would say mostly on text blocks that already exist and you click into to edit.. but it has also happened on fresh text block.
The Navigator, on the other hand, is EVERY TIME...
1. Open Navigator and open a folder and select a LAYOUT (actually make it the current layout / bold letters, etc.)
2. Scroll the Navigator so that the previously selected layout no longer appears in the window of the navigator..
3. Try to double click any folder or layout in the current navi-window.
4. The navigator will jump to display the current layout in the navi-window and your 2nd click will be on something else...
Duane
Visual Frontiers
vfrontiers
BTW,
I know I don't think like anyone else (here or anywhere!)... but for my money, I'd like to see bug reports happen in a forum where other USERS can try to duplicate as well as GS techies... Don't know why we have to GS C.O.N.T.R.O.L. to type in our bugs in secret...
Like I said, I don't think like anyone else... and it is GS's to run as they like...
Anyway.... I figure if enough speak out here, they'll get it...
Duane
Visual Frontiers
Just tried this and it works as expected on my Mac. No jumping around. Haven't tried Windows.
vfrontiers
What is the easiest way for me to do a Screen movie? (mac)
Duane
Visual Frontiers
vfrontiers
Ok... Thanks Matthew...I did explain it wrong (cuz that's the way my memory is these days)...
1. Open up navigator palette
2. Select any layout that's INSIDE a folder... It does not need to be the current...
3. Close the folder
4. Select a different folder and the folder containing the selected layout will POP open...
I'm trying to attach my .mov from snapz....
Duane
Visual Frontiers
