ArchiCAD 15 announced
ArchiCAD 15 has been announced today:
http://www.graphisoft.com/community/press_zone/ac15.html
Detail info about ArchiCAD 15:
http://www.graphisoft.com/products/archicad/
Note: Videos are continuously uploaded to the site. All in all there will be 100+ videos about the release.
28 Replies 28
Erika Epstein
AC15 has some great new tools and features. I've always modeled a lot in the 3D window.
- The new reference plane which came with the MEP tool is now in archicad. It is adjustable and lets you place it where and at what angle/plane you need it.
- the shell tool, finally we are no longer limited to basic shapes and geometries. It's fun sketching/designing in 3d. I've been able to create parametric shapes easily and quickly. It's limitations right now are edge handling and inability to place doors and windows in the forms. You can place skylights. Current design trends blur the distinction between wall and roof so hopefully this will be addressed quickly. For now, just place a wall in an opening and place the d/w in the wall.
The renovation manager, long overdue, works really very well. Instantly the need for dedicated layers to distinguish between existing to remain, demo and new is gone. E,D and N are set by each element and display is controlled by the renovation status. You will need to redefine your views with the reno status, but it so much simpler to work.
I particularly like that in renovations when a door or window is replaced or eliminated this is now set by the element status. For example if you are replacing a door, you set the existing reno status to demo and then in the same [exsting] wall place a door with its reno status set to new. You don't have to cut out the wall around the door and duplicate the wall so you can put in a new door. The reno feature handles this. A drawback is that as yet, you cannot separately set the reno status for frame and door.
I also like how it handles door/window openings.You don't have to cut out the piece of wall a demo d/w sits to demo the entire wall and put in a new wall in which to place the door. You can put a demo d/w and a new d/w in the same wall and the renovation filters handles the rest.
The renovation status greatly facilitates presentations when you need only flip through the different filters to show existing, demo, after demo and new. This is a big hit with owners and contractors and ye olde bosses.
IFC is also improved, which is so important in the big BIM picture of being able to exchange data with the rest of the team. but that's for another post.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Is it possible to make a round (circular - spiral) ramps for the public car garages (parkings), in Archicad 15?
Here is the example of one:
There is an ArchiCADWiki article that talks about Spiral Beams:
http://www.archicadwiki.com/SpiralBeam
There it says you can use the curved ramp object to create these Spiral Beams.
I would say that would be the first method to try to achieve this.
Then one could also create the segments of the curved ramp out of Ruled Shell pieces.
I hope will be soon available the demo version.... Anyone knows something about?
Let's have fun with AC15!
seemingly availble soon at https://www.myarchicad.com/ . (or at least when the versions are out) Im looking forward to checking out some of the new features in the demo asap
With spiral ramp by Archistair is easy to do custom spiral road with balustrade
Other way is with Cadimage customprofile and 3d polyline
Or make a circular wall with oblique empty windows
for balustrades and perfect circular contours
not fragmented with rectilinear fragments
jatassoc wrote:
Apparently still no import of Sketchup 3D warehouse objects into MAC OSX version. Or their not saying. The lack of up to date real object (such as name brand appliances, etc.) is a real drag.
There is indeed a sketchup import/export add-on for macs now in 15. Check the help menu / ArchiCAD downloads website. It works okay but the objects trianglulate too much sometimes. But, overall I think it's great to finally have on the mac.
I used the “Curved Ramp” Object method as a solution for Spiral Beams, and it worked perfectly. Thanks Laszlo.
I created the whole garage in Archicad 12:
http://imageshack.us/f/856/111dc.jpg/
then exported it as .3ds, imported in Rhino, and created the outer curtain wall:
http://imageshack.us/photo/my-images/577/unled4t.jpg/
Cool.
