AndorSzoke
ArchiCAD 16 Hotfix-2 (build 3270) released
We have released Hotfix-2 (build 3270) for ArchiCAD 16. This hotfix contains fixes for several Energy Evaluation problems, IFC bugs and improves display quality on Mac computers with HiDPI display.
The Hotfix is currently available through the automatic update system for INT, USA, AUS, NZE and GER language versions. Other language versions will be enabled as they pass QC. You can find a list of fixed bugs in the release note:
http://www.graphisoft.com/support/archicad/downloads/ReleaseNotes/AC16-3014to3270-ReleaseNotes.html
AndorSzőke
Product Management
GRAPHISOFT SE
Follow us on Twitter
GRAPHISOFT HelpCenter - the ArchiCAD knowledge base
17 Replies 17
Katalin Takacs
As we guessed the download process of the Hotfix installer was not completed in this case and the issue could be solved by downloading the exe file again.
Katalin Takacs
Jacek
Hi Katalin,
Unable to complete the update. Successful installation of the first two updates but stops at ArchiCAD 16.
I am on AC16, with successfully installed previous updates. For some reason the update can not access file ArchiCAD16?
Any suggestions; all applications are turned off during update. Mac 64 bit.
Thanks,
Jacek
Ps. Update -was able to install it without a problem on my desktop computer without a hitch. So this suggest an issue with the laptop?
jacek lisiewicz
arkhos-tekton, architects
carmichael, ca
Mac OS X 10.15.5
IMac Retina 5K, Intel Core I7
32 GIG Memory, AMD Radeon R9
ArchiCAD 24
Jacek
OK, I am posting to myself; I uninstalled ArchiCAD and reinstalled it.
Ran the upgrade and it worked without a hitch. Something had gone array before and hence the problems, I think.
It all seems to work fine.
Thanks, sorry for the distraction.
Jacek
jacek lisiewicz
carmichael, ca
Mac OS X 10.15.5
ArchiCAD 24
Hello -
I need this dotted line issue fixed for ArchiCAD 12! Can you provide a hotfix for that please?
Thank you so much..
Thank you so much..
I don't believe ArchiCAD 12 is supported any longer.
Fra
Any news for released Hotfix-2 (build 3270) for ITA language?
Francesco
AC25 AC26 (Ita)
Mac Studio M1 Max 64 GB - OSX 12.4
Katalin Takacs
Dear Francesco,
the ArchiCAD 16 Hotfix 2 (3270) is now available for all language versions.
Katalin Takacs
Fra
Thank you, Katalin
Francesco
AC25 AC26 (Ita)
