AndorSzoke
ArchiCAD 17 Hotfix 5 (build 5014) Is Available
ArchiCAD 17 Hotfix 5 (Build 5014) for ArchiCAD and BIM Server has been released today for the INT, USA, AUS, NZE and SWE language versions. Other language versions will be enabled as they pass Quality Control. This hotfix solves the regression crashes introduced with Hotfix 4 (build 5005) previously published for a few localized versions and also contains the bug-fixes that Hotfix 4 contained such as fixes for numerous BIMx and Energy Evaluation problems, crashes and many other issues. You can find the detailed list of fixed bugs and the download links in the release notes:
ArchiCAD 17 Hotfix 5 (build 5014) Release Notes
AndorSzőke
Product Management
GRAPHISOFT SE
Follow us on Twitter
GRAPHISOFT HelpCenter - the ArchiCAD knowledge base
13 Replies 13
Marton Kiss
Link wrote:
I suspected the same. I might try getting the official word from GS.
Link,
be careful with the preference cleaner. If you have a version that was released prior ArchiCAD 13, it might erase your local Teamwork data without any questions. Deleting the files manually - as in the article - is the safest way to do.
I have updated the article to reflect Windows 8 and 8.1 - basically there were no changes in paths.
Marton
Marton Kiss
Chief Product Officer
GRAPHISOFT
Link
Thanks Marton
Do you have the latest version of the cleaner available by any chance?
Link.
Marton Kiss
Sent you on Skype . For others who may need it: ask the local GS Support team and they will help you out.
Marton
Marton Kiss
GRAPHISOFT
Link
Thanks Marton.
See you in April!
Link.
