Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
floor plan tutorial
Is there any good tutroial fot theese kind of details? http://shrani.si/f/A/5W/3gi6Zgjk/capture.png
3 REPLIES 3
With Building Material Intersection Priority Numbers properly set up, these details should clear up pretty nicely.
For that detail you are showing you could model it out of a Complex Profile. The horizontal stretch zone of the profile should be at the top of the details so you could model the stepped basement wall using a single profile. You would have to place 5 pieces of that Complex Wall, each with a lower base. If you set up the horizontal stretch zone of the Profile properly, only the vertical complex Wall part of it will stretch.
I allready made this kind of walls with material intersection priority. I just dont know now how to copy these details from sections to floorplan. I would just like to copy one 2d part that won t be seen in 3d. I hope you understand what i mean
OK, I get it. You want to show those details in the Floor Plan.
You can simply draw a Marquee in the Section, copy it to the clipboard and paste it in the Floor Plan.
