2014-05-06 03:44 PM
2014-05-14 02:09 PM
2014-05-14 06:57 PM
2014-05-15 04:41 PM
Dan wrote:Would this help?
And why still no update to the Renovation Tool so you can set the renovation status of individual skins in composites - currently there is no (easy) way to add say a new external insulation layer to an existing wall, which is a pretty common requirement now for retrofit / refurb. works.
2014-05-15 04:55 PM
2014-05-15 04:58 PM
2014-05-15 05:56 PM
Jussi_ wrote:Not sure where you read that, but my old blue wibu dongle works fine with 18 beta, and there was no mention of an issue after release, that I have heard. Most of the files I still use, daily, were started in the 90's, and I never have issues other than library parts. That that was help a lot with the migration libraries and auto conversion. Changing over from Plotmaker was the biggest hassle, but obviously worth it.
I read that WIBU dongles need to be changed, since AC18 does not support it any more. .
2014-05-15 06:27 PM
kevin wrote:Unfortunately not - a wall can only hold one accessory.
Can you add multiple accessories to the same wall? For instance, one placed with Demo renovation filter and one placed with New, so that you could show stripping off of old material and adding new.
2014-05-15 07:07 PM
2014-05-15 07:16 PM
Chazz wrote:Although some consultants are a bit sketchy.
Photo-realism is why they invented consultants.
2014-05-15 08:52 PM
Chazz wrote:My take-a-way from watching that video... "Ok, now we're completely lost".
Proof of this is in the rendering demos which are horrendous admissions of failure. You could spend the rest of your life just fiddling aimlessly with the endless settings to get a good concrete texture.
