2014-05-06 03:44 PM
2014-06-27 05:29 PM
2014-06-27 05:52 PM
another Moderator
2014-06-28 10:23 AM
csparchitects wrote:Your graphic card that you own right now will always work better in 2d comparing it to any GTX card because it is optimized for that kind of work and that's info for Autocad.
I'm not sure an SSD HD will help our issue. It's the sluggishness in 3D and 2D viewing we are having problems with.
2014-06-30 04:05 AM
2014-06-30 07:05 AM
Eduardo wrote:Hi Eduardo:
Finally : a smart keynote object with many styles to choose from!
2014-06-30 11:20 AM
ejrolon wrote:What are the size of jobs are you working on?
FWIW in my case running in a six year old Mac Pro AC18 is perfectly acceptable for rendering and regular Teamwork. No SSDs.
2014-06-30 01:04 PM
2014-06-30 05:26 PM
Stress wrote:Hey Marc,Eduardo wrote:Hi Eduardo:
Are you referring to something other than "Keynote Indicator_NCS 18"?
2014-07-01 11:37 AM
ejrolon wrote:Was this rendered using your Dual Quad machine with 18GB of RAM? If so it would explain why AC18 runs OK.
30,000 Sq.FT project is the biggest and the test file I use for the new versions, though that could be it, the others are in the 2,000 to 5,000 range.
2014-07-01 01:24 PM
another Moderator
