Erwin Edel
ArchiCAD 19 toolbars moving around
Whenever I launch a new ArchiCAD 19 session or make adjustments to my Work Environment settings, the top toolbars move around.
It seems like ArchiCAD decideds there is some space on the top and it moves the toolbars around to fill it.
I have a work around where I keep re-applying my saved Work Environment settings, but it's a bit annoying.
Bug or feature?
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
7 Replies 7
I think this is a bug.
Also will be very good, if toolbar locking option will be added.
Roger C
It happens to me, too. Really annoying.
+1 on the option to block toolbars layout, or even workspace.
If anyone gets a solution, let us know.
i7 3770K / MSI GS73VR 7RF i7 7700HQ
16 gb
GTX 3060 / GTX 1060
Windows 10
ArchiCAD 25 SPA
Katalin Borszeki
Hi All, this is in fact a bug. Thanks for sharing. It is now in our database to be corrected. k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
shtarkel
Is the issue solved in Update 4003 ?
Katalin Borszeki
NO, unfortunately this problem does not have a high priority.
Katalin Borszeki
GRAPHISOFT
Is there any way to get the priority higher? This is extremely annoying.
We have updated to ArchiCAD 20 and this bug is still there! I can't believe that nobody took the time to update this annoyance in between versions.
