ArchiCAD 19 wrong reference point
After updating to 4011 version, I've noticed this very annoying bug.
Very often when trying to offset one edge or all edges, I've got a wrong reference point and therefore if I click to end point or edge, I will get wrong result. Sometimes reference point appearing on nearby edge, sometimes on random nearby location.
This can also happen when moving a node (will attach screenshot in next post), inserting new node and curving edge.
Here is a video, I've captured from my screen. In this 2 minutes I've reproduced this bug 5 times (first on 0:24):
https://www.youtube.com/watch?v=8pE_4UAOuSw&feature=youtu.be
Bug exists in 3D too.
16 REPLIES 16
When moving a node:
Erwin Edel
You're not alone http://archicad-talk.graphisoft.com/viewtopic.php?t=50731
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
NCornia
This offset feedback issue has been reported along with other items in that thread that Erwin mentions. I have made it clear that these items need to be attended to as quickly as possible.
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Thanks for answers. Hope this will be fixed in ArchiCAD 19.
Brad Elliott
Any feedback on a timeline for this fix? My productivity has taken a beating because of this bug.
Mac OS12.6 AC26 USA Silicon
M1 Macbook Pro
NCornia
Brad,
I do not have a definite ETA, but it is a top level task for the developers and the plan is to release an Update specifically for this issue as soon as possible.
Best regards,
Nicholas Cornia
ARCHICAD on Twitter
Tutorials
Katalin Borszeki
Hi All,
Thank you for reporting this issue, we have been aware of it and the fix is under development.
The topmost entry in this Helpcenter article http://helpcenter.graphisoft.com/?p=43114 describes the node offsetting and dimension placing problem.
Please note, the issue is planned to be fixed very urgently in a fast fix!!!
Thanks, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
Same for me. Very often I have to repeat my actions two or three times to get correct result.
KatalinBorszeki wrote:
Hi All,
Thanks, k
Hi, Katalin, thank you for good news. ^_^
And also sometimes Stretch command missing when clicking on wall reference line endpoint. I hope this will be fixed with next update too.
