Archicad design tools: Workflows, element connections, modeling tips
ArchiCAD 22 morph subselement selection
giza
Maybe it is already mentioned somewhere in forum, in ArchiCAD 22 there is minor issue with cursor icon when using subelement selection tool, regardless if the quick selection is active or not the cursor icon shows with magnet.
Maybe screenshot can explain it better.
Gezim Radoniqi | Architect | BIM Manager @ 4MGroup
ArchiCAD user since version 6
AMD Ryzen 3950X CPU, 64 GB RAM, NVidia RTX 3060 12GB
1 REPLY 1
I do not think this is a bug.
It worked like this since AC16 when the Morph Tool was introduced.
When you are using CTRL-SHIFT to select sub-elements you WANT to find Edges and Faces of Morphs, so of course the Magnet is active regardless of whether it is turned ON or OFF in the Arrow Tool Info Box.
Of course, when you stop using CTRL-SHIFT, the behaviour or the Magnet return to the way you would expect it.
