fuzzytnth3
ArchiCAD 23 Curtain Wall edit boundary
You used to be able to use the Menu command
Design/ Modify Curtain Wall / Extract Boundary to fill
to edit the perimeter boundary of a Curtain Wall in Elevation
However in AC23 I'm not seeing that Command in the menu system and I've tried switching back to the ArchiCAD default Work Environment. So how do I go about editing the boundary of the CW to follow the lines drawn in the attached screenshot?
Using AC25 5005 UKI FULL
4 Replies 4
Erwin Edel
I do miss the 'extract boundary to fill' method as it was brilliant for quick mock ups with CW.
That said: open your elevation, select the CW and click 'edit'. You should see a sort of 'layer' menu. If you show 'scheme grid'and hide the other options, you are left with a box 'fill' that you can edit as any other polygon in ARCHICAD. Hope that helps!
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
fuzzytnth3
Excellent thank you. Means I can issue my drawings today
squall_tmo
The "Fill to CW" group of functions is still in ARCHICAD, but they are now hidden:
you just need to go to Options > Work Environment, then go to "Menus" and if you try to organize functions by theme you will find the folder "19 Curtain Wall":
All the old functions are right there, you can place them in your own work environment!
Erwin Edel
Ah, that is good to know. Thanks!
www.leloup.nl
