Chazz
ArchiCAD 9 Hotfix Build 2172
http://tr.graphisoftus.com/ wrote:
ArchiCAD 9 Hotfix (Build 2172) can be found within the ArchiCAD 9 application menus. Go to the [Help menu >> Check for Updates...]. When appropriately installed, ArchiCAD 9 [Help >> About ArchiCAD] will show as Build 2172. You may also use the mirrored links: ArchiCAD 9 Hotfix (Build 2045) Mac {48.5 MB} / Win {31.3 MB} This version is for non-EDU users only.
Anyone tried it?
And why would the mirrored link be for 2045?
Nattering nabob of negativism
20 Replies 20
Crash, Crash, Crash ... sending lots of reports.
__archiben
germond - are you mac or pc? crashing from AC or PM? crashing when doing the same things over and over (what?) or just generally?
~/archiben
b e n _ f r o s t
Downloaded and installed the update. Everything seems to be working fine so far.
Edit: Not fine; see later post.
I'm sorry, I am on a Mac, G5, 4meg ram, OS 10.4.3. Crashes are occurring in ArchiCAD on an existing file which I'm trying to modify (Changing window parameters and some trim objects). They seem to happen when I "save" in an elevation window, not, so far in the plan view. Still testing... RBG
Had a problem with accessing project files on the server with the new build.
http://archicad-talk.graphisoft.com/viewtopic.php?p=50122#50122
I have been to the download section on Graphisoft Support and can find no mention of a build 2172 update. The current build referred to for hotfix 3 is 2045. Am i missing something obvious here or....not?
You can get to the download by going to the help menu from within Archicad. I figured this was a security feature to ensure that only current users can get to the download.
I was (finally) able to load 2172 on a few machines this morning. I wonder if there is a difference in the files linked at the following Graphisoft sites:
http://www.graphisoft.com/support/archicad/downloads/update.html?_submitted=1&version=9&lang=USA&bui...
I was never able to successfully extract the file downloaded from tr.graphisoftus.com (even trying/testing on Macs outside our office). Errors such as "end of central directory not found" were common. The file downloaded from the other site extracted flawlessly.
Something to check, I guess?
Eduardo Rolon
Same thing happened to me. By some strange reason I was able to connect to graphisofts.com and download it and extract. The file downloaded from tr.graphisoft.com never did unzip successfully.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Graphisoft has repaired the link at tr.graphisoftus.com for the Mac 2172 hotfix so that the file can be successfully downloaded and unzipped. While they were at it, I also asked them to repair the 2045 v. 2172 typo. Onward.
