2005-12-05 04:37 PM
http://tr.graphisoftus.com/ wrote:Anyone tried it?
ArchiCAD 9 Hotfix (Build 2172) can be found within the ArchiCAD 9 application menus. Go to the [Help menu >> Check for Updates...]. When appropriately installed, ArchiCAD 9 [Help >> About ArchiCAD] will show as Build 2172. You may also use the mirrored links: ArchiCAD 9 Hotfix (Build 2045) Mac {48.5 MB} / Win {31.3 MB} This version is for non-EDU users only.
2005-12-06 11:55 PM
2005-12-07 12:12 AM
Germond, wrote:germond - are you mac or pc? crashing from AC or PM? crashing when doing the same things over and over (what?) or just generally?
Crash, Crash, Crash ... sending lots of reports.
2005-12-07 12:30 AM
2005-12-07 01:49 AM
2005-12-09 07:15 PM
2005-12-10 05:01 PM
2005-12-10 07:08 PM
2005-12-12 05:22 PM
2005-12-12 05:42 PM
Ted wrote:Same thing happened to me. By some strange reason I was able to connect to graphisofts.com and download it and extract. The file downloaded from tr.graphisoft.com never did unzip successfully.
I was (finally) able to load 2172 on a few machines this morning. I wonder if there is a difference in the files linked at the following Graphisoft sites:
http://www.graphisoft.com/support/archicad/downloads/update.html?_submitted=1&version=9&lang=USA&bui...
I was never able to successfully extract the file downloaded from tr.graphisoftus.com (even trying/testing on Macs outside our office). Errors such as "end of central directory not found" were common. The file downloaded from the other site extracted flawlessly.
Something to check, I guess?
another Moderator
2005-12-15 04:37 PM
