Ben wrote:
I don't quite understanding why profiler will not do that roof. attached is a curve that was done using profiler (it is 250m long). The trick is to always use splines. The resolution of the curves is far superior. Ie splines for the profile and magic wand a path that is a spline as well. Hope this helps, albeit a little too late.
I think it is about time GS took profiler out of the goodies and into the addons folder. It is so powerful but most new users would not even know it exists
Cheers
Ben
I should mention that we had previously tried splines for some fo the double-curving objects that we model on our office and we noticed that spline-formed objects (even simple slabs) tend to guzzle copious amounts of memory to the degree of noticeably and progressively slowing down each regeneration iteration in the 3D window as the project file grows in size. And woe be to you if your splines are exceedingly large in size. I realize that this is probably something that would not be a factor (or possibly even observable) to you given your rather impressive hardware, but like I mentioned in one of my prior posts, we are a relatively small firm without the healthy tech-budgets of other firms and the similarly meagre (my today's standards anyways) equipment.
In other news, Gehry Technologies has just jumped into the BIM field with the release of its AEC parametric software suite, 'Digital Projects'.
http://www.tenlinks.com/NEWS/PR/gehry/050604_software.htm
There's also a brief article about it inthis month's
'Architectural Record'
I don't know much about it other than that it is a scaled down version of CATIA ( which, as anyone familiar with the software knows, is a pretty powerful 3D CAD/CAM/PLM software suite{and expensive too!!!}) and specifically geared to the needs of architects, contractors, engineers, building managers in not just the design and construction of the building, but the entire Product Lifecyle management of the building. Now we all know how 'out there' Gehry's design process and designs tend to be, so I imagine it will be easy to accede to the temptation to dismiss this as a something out of the reach of ordinary mortals and which will eventually price itself out of the AEC software market for ordinary architects or remain a niche product for high-end/high-profile architects of the Gehry-Foster-Meier-Pei class. But given that Gehry Technologies/CATIA is partnered/backed by the Dassault-IBM business group and given IBM's marketing leverage, I seriously think this is something to keep an eye on, especially also given the Gehry Partners' extensive experience with complex project management. Let's also not forget that it was Gehry's success in Bilbao and most recently in LA (Walt Disney) and MIT ( Strata) that has largely given impetus if not drive to the whole BIM movement particularly in the 90's when it was still an oddity for most architects. Let's also not forget that despite the fact that Gehry Technologies, the subsidiary that is directly responsible for the Digital Project suite, was formed only 2 years ago (2002), they've spent a better part of the late 90's studying other BIM software (read Microstation, Revit and ArchiCAD) before deciding what not to and what to include in their own package along with other traditional strengths of CATIA.
With Revit backed by big A (utodesk) on the one side and Gehry's 'Digital Project' backed by big Blue (IBM) on the other side, it seems like things are about to get rather interesting ( if not hot) for the R and D team at Graphisoft. I can only hope that this means that we will get a considerably amped up release of AC in v10 with an inclusion of a more significant number of our wishes from the wishlist, as GS tries to keep up with the Jones'.
The Plot thickens!!!!!
