2007-01-22 08:52 PM
2007-05-07 02:54 AM
ivg wrote:If I understood correctly, I feel that you are mentioning something that already exists in both softwares.
Evaluation criteria can be different. mine, for instance is as follows
If i need a component like a wall (curved one, for example) to place in detail on a drawing sheet with all the dimensions, volumes (automatically calculated) etc requested for consequent production do i have to draw a component from scratch or i can reuse one existing in the project as 3d model..? (selecting different views of the component and placing them on a sheet would have been a perfect workflow) So my major major evaluation criteria is the ability of software to document BIM components in a proper way..
Another concern os if a component changes ints geometry is it changed in the drawing sheet as well (if we admit we can place component views on a sheet)
Thanks for answers in advance.
2007-05-07 10:54 AM
refs wrote:So you want to have window frame tool and door knob tool to make them real parametric BIM objects?
Miki woodie/Tomtomas:
As I have mention before, for me it's not "true bim" to have to do parametric objects (windows, doors..Etc) with “slabs” tools, because it’s difficult to work with our parametric programming language. It’s like to use “ramp” tools in revit for wall under Spiral Staircases. This is “workarounds” …
2007-05-07 11:43 AM
- In Revit, it’s a tool called “LEGEND”/Schedules (wall type schedule, door frame schedule, and so on + Legend).
- In AC it’s called “INTERACTIVE ELEMENT SCHEDULES AND LISTS”.
2007-05-07 05:40 PM
model..?
Well, to be specific, i don't know what workflow is used in other countries but what we use here is we take an element, place dimensions on it and put it on a drawing sheet.. I' asking AC people cause I can't accomplish it in Revit. Revit can't dimenson its own 3d element in a legend view unless you draw that component from scratch all over again.. neither it can trace an element.. So the question is for AC users can you somehow get let\s say a cylindrical panel projections, place dimensions on it, or you draw that element projections from scratch, place dimensions and then put it on a sheet?
2007-05-07 05:42 PM
Tomtomas wrote:Tomtomas,refs wrote:So you want to have window frame tool and door knob tool to make them real parametric BIM objects?
I think that approach used in probably all current AEC (BIM if you like buzzwords) applications - having different object types and different tools for walls, slabs, roofs, ramps etc is actually wrong (as shown by ramp under stair example). I see it as result of trying to dumb down the process of modelling. Use foundation tool to draw foundation, use slab tool to draw floor slab, use wall tool to draw some walls and use roof tool to make nice roof. That's ok if all you want to design is "traditional" boxy house (or you are teaching CAD/BIM in kindergarten). The problem is, that in "modern" architecture it's often hard to tell if the wall is the wall, and slab is a slab.
Please look at Kubuswoning:http://peetjuhsplekkie.web-log.nl/peetjuhsplekkie/images/rotterdam_casecubointero.jpg
Now could you model such house in Revit without "workarounds"? Just using "real BIM tools"? Just be honest.
In real life I don't care about "purity of BIM". If roof tool fit's me better to model walls than wall tool - I will use it. I would like to have some generic tool actually. I would like to draw some freeform 3d object, be able to cut any opening in any direction, insert any symbol in any opening and then jus set some property of the object to "wall", "roof", "slab" or "ramp". But I know that "ease of use" would suffer and "ease of use" is Holy Grail of CAD/AEC/BIM marketing.
2007-05-07 06:02 PM
2007-05-07 06:02 PM
2007-05-07 06:08 PM
Bricklyne wrote:As with any troll - the only cure is to ignore.
Because, after all, none of us have heard that one before and need him to remind us.......again........and again. Right.
2007-05-07 06:53 PM
Tomtomas wrote:Actually, you could. You'd have to use the massing tools, and create volumes to represent the building; then skin on the walls/roofs. One non-elegant aspect is that you'd need to use windows for roof objects (which can also be inserted into wall objects) in the walls to get them to be parallel to the slope of the wall. Windows for wall objects in Revit are always vertical -- go figure!
2007-05-07 07:58 PM
