ArchiCAD file recovery after a crash
Hello ArchiCAD-Talkers,
ArchiCAD crashed on me today, but when I try to open the .pln file I get a warning box saying "Cannot Read Plan File", after saying o.k. to this, it then proceeds to open but the file is void of any elements. I tried the .bpn, and it has some columns, but that is all.
I tried the "forward merge" tip (tips and tricks), but this doesn't seem to work either.
Am I doomed here, or is there another option to recover all the work done on this project?
Any Suggestions?
4 REPLIES 4
It sounds bad Brent.
Is the .bpn so sparse because that was all that was saved, or is it missing things it should have?
Is it a lot of work lost? With the .bpn so sparse I am assuming it's not more than a day's work. It may be easier to redo than trying to recover. I have found in the (thankfully rare) occasions when I have lost data that it takes about one fifth the time to redo it since all the thinking has been done.
Well Matthew,
Actually all that was opening in the .pln was some steel columns. The .bpn had nothing in it. If it was a days work I would not be too upset, it was more like about two weeks, I was finishing up on the details for the building. The problem is the deadline for submission is this morning.
I am not too sure how ArchiCAD files work but, the .pln & .bpn are showing 9.72MB, which confuses me as a "new and reset" is about 1.2MB.
I have found a back-up CD with an earlier version of the project (no-where near the finished product), and I do agree with you, the second time around is quicker.
Perhaps you should contact GS about having a look at your file. It seems from the file size that at least some of the data is there.
I am assuming that you have looked for the data in every conceivable way; all layers on, all stories, all sections and 3D views.
It would be nice to have a file recovery utility for emergency situations like this, even a rough and ready one in the Special Menu. It would be especially nice if it could provide some reporting of actual errors found. This could even be a benefit to the development/debugging process. Even just extracting readable elements into modules would help.
I think I will take your advice and send GS the file, maybe they could figure it out. Hopefullly we (GS users) would benefit from a stronger programme.
