ArchiCAD student version Google Earth Connections
Hi, I have the student version of Archicad, and I tried installing Google Earth Connections, but I cannot find the Google Earth Connections sub-menu under File in Archicad. Is it not possible to use addons with the student version?
6 REPLIES 6
David Maudlin
ElinaH:
Maybe after installing the add-on, you need to go into the Work Environment and add the commands. Go to Work Environment > Command Layout Schemes > Menus: set List to All Commands by Theme, then scroll down to 17 Add-Ons > Google Earth In-Out > Google Earth Connections.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Alright, I checked there, but I didn't find any mention of Google Earth under 17 Add-Ons. Does it need to be installed in a specific place?
Hmm, I just checked under Add-On Manager and when I click on one of the Google Earth related Add-Ons, it says "The file is an outdated Add-On that cannot be used with this ArchiCAD version." I guess that just means it isn't compatible with the student version. What a shame.
Eduardo Rolon
Not necessarily. It might mean that you need to re-apply the latest patch to get it to work.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
That did it! Thanks a bunch! Without you I would've already given up!
yea me too. i cant find Google Earth Connection in d command folder. is it not available in student version?
