Archicad 10 hotfix (build 987) is out now
Greg Kmethy
We have released a hotfix for Archicad 10 (build 987) for the PC and Mac PowerPC platform (The Intel mac version released 2 days ago is compiled from this build too, so Intel Mac users don't need to install this). Some language versions (e.g. NZE, FRA, FIN) are not yet available, but will be uploaded early next week. The patch applies to the education licences too.
Gergely Kmethy
VP, Customer Success, Graphisoft
40 REPLIES 40
gkmethy wrote:
We have released a hotfix for Archicad 10 (build 987) for the PC and Mac PowerPC platform ...
Where can we see the release notes about what was fixed in this hotfix?
Thanks,
Dan K
Here
Richard
AC26 (since AC6.0), Win10
Aussie John
Labels in section view not working!!!
Add a label to any element in a section view and they are invisible. Select label tool and command A and they are highlighted but invisible.
I cant even test if the previous bug of crashing when a drawing tried to update when an object had the object label applied.
This means you cant apply window door codes to any elevations.
hotfix 3 hurry up
they appear to work if you use the arrow/ID option but not if if you use a label object
Cheers John
[/size]
Aussie John
The bug whereby a column with a wall stopping at the edge of the column (rather than passing through) doesnt provide a recognisable boundary for a zone is still present
Cheers John
[/size]
Aussie John
Some more testing:
Even though you cant see them - add an object label to an object in section. Save as a quick view and add to a layout. It will crash Archicad when updating.
I would of though any crashing bug reported to GS would be at the top of the priority list to be fixed.
This seriously effects my work flow as I attach a label in plan and dont have to retype the description again in a section or elevation view.
Cheers John
[/size]
Rod Jurich
Aussie wrote:
Some more testing:
John, considering your earlier posts would you suggest updating is worth this extra hassle.
Rod Jurich
Aussie John
if you rely on labels in your sections and elevations then no. At least in build 966 you could attach ID numbers to window doors and basic note to slabs etc
(although sadly not objects)
Regardless the issue with crashing is with all the issued builds
Cheers John
[/size]
After installing I see some graphic mistake in 2D window....
Could you be more specific, please?
Richard
