Archicad 14
Does anyone heard something about Archicad 14?
what new or improved features or release date or something?
Thanks
107 Replies 107
Achille Pavlidis
freskim81 wrote:
They had to modify everything inside the AC13 to work perfectly in Teamwork
Ehmm... having used TW2, let me tell you that "perfectly" isn't the word I would be using...
Mac OS 26.4 | AC 29.2.1 INT 5101 FULL
owen
Interesting, OSX i see ... corrupted files by chance?
I thought Graphisoft had solved their TW issues on the Apple side of things ... but I have just recently returned to an XSAN environment and hearing we should hold off on TW2'ing our project because of 'ongoing issues' resulting in corrupted files.
I have yet to verify personally .. anyone else had any experiences on this issue?
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
freskim81 wrote:
Did you mean BEST Upgrade Graphisoft ever had....don't forget about Teamwork 2. (They had to modify everything inside the AC13 to work perfectly in Teamwork) ...and for that Teamwork is major improvement for ArchiCAD 13.
For New features we have to wait for NEXT version.
Sorry but if you did read above , i work on my own, and not in a company. Teamwork is useless for me. So for me and all users that do not use TW, AC13 was a complete waste of money (to put it mildly)
Dwight
Bricklyne wrote:
living in a land of mirages and lost hopes and dreams.
You describe the entire path of Archicad development in just one line.
Dwight Atkinson
But we keep on using it to do the stuff.
Archicad, what else?
Dwight
The BIM that dare not speak its name.
Dwight Atkinson
Achille Pavlidis
well... you can give a look here, here, and here...
owen
OK well XSAN is not the issue anymore - the BIM Server is on regular drives. We are having problems with corrupted (non-TW) files though which are on an XSAN, although not sure if this is the problem or the fact the files had been started in AC11 and something is getting screwed up in the 11>12>13 conversion process.
Anyway it is all making me very hesitant to jump into TW2 - I have used it without problems so far but not in this environment or at the scale i'm now looking at.
cheers,
Owen Sharp
KenMcN
Owen
Have you checked permissions on the 'corrupt' files?
I've found Archicad doesn't always inherit the permissions of the enclosing folder, as it is set to do via OSX Server (particularly if Access Control Lists are used).
Sometimes this prevents other people from opening a file.
Just a guess…
V25 & 26 (fully patched); Mac Ventura, MacBook Pro M1 Max
KeesW
Any chance of getting back to the topic - i.e. ArchiCad 14?
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
