I don't recognise the video card - but it doesn't seem to have much memory - 500MB?
Have you checked to see if you have the latest drivers?
This can often be a cause of problems.
Also check you are using the latest hotfix for Archicad.
Is there anything in particular that causes the crashes - i.e. when viewing in 3D or when trying to edit a particular element?
I am not familiar with this machine but just having a quick look it seems a fairly low spec machine although it is suposed to be aimed at the professional workstation market?
But I am no expert on these things so maybe someone else can offer an opinion.
