2013-06-23 07:16 PM
2013-06-23 07:49 PM
For construction elements (Wall/Slab/Beam/Column/Roof/Shell/Morph/Mesh): Cut fills are assigned via the Building Material attribute. When such an element is exploded (e.g. in a Detail Drawing), the resulting fill will be in the Cut Fill – Building Material category. A detail Fill in this category retains the Physical properties of the original construction element.
For example, if you draw a fill as a detail patch, to be used as a cut fill, change its category from “Drafting” to “Cut Fill – Building Material”. This way, this fill will behave like the Building Materials of construction elements in the project,I'm glad you asked, as I hadn't noticed this feature.
2013-06-23 11:23 PM
2013-06-24 03:46 AM
