Archicad 19 - Adjusting Wall heights Section
Hi Everyone,
Our office recently updated to archicad 19 and we are finding that we can no longer manually increase wall heights in section. Is this a glitch or is there a setting I need to adjust?
We are running archicad on PC.
Any help on this would be most appreciated.
Kind Regards,
Walter
4 Replies 4
I have moved this post to "Working in Archicad" section.
Hi Walter
This was an issue when 19 first came out and seems to have been fixed. If you haven't installed the latest update I would recomend trying that.
http://www.graphisoft.com/downloads/archicad/updates/AC19/AC19-4013to5005-ReleaseNotes.html
It could also be because your selected wall is part of a group, so not all pet palette options are available. Suspend groups then adjust height.
I tried suspending the groups, but had no luck. Will try downloading the update and go from there.
Thanks for your help, most appreciated.
Walter
