Archicad 22 update and Goodies
Some of my french clients are still on AC22 4XXX or 5XXX. I offered to install the Goodies for them so that they could import 3DS files (for example). But the download archive links seem to be cut off from many Archicad maintenance updates.
They are not able to update their old AC22 by this link anymore :
https://graphisoft.com/downloads/archive?#ARCHICAD20
Where can we find these precious files?
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
8 REPLIES 8
Hello Christophe,
Did you try here: https://graphisoft.com/downloads/goodies/ac22/int
And here is the French version: https://graphisoft.com/downloads/goodies/AC22/FRA
Thanks Braza,
I find Goodies finaly but not AC22 update yet 😕
Christophe - FRANCE
Christophe wrote:
Thanks Braza,
I find Goodies finaly but not AC22 update yet :/
Are you saying that "Check for Updates" within the product does not work to send them to the proper download page?
AC 29 USA and earlier   â€¢   hardware key   â€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Hello Karl,
I can easily download the correct update that I need. For example, if a client asks me to intervene occasionally on a shared project, I do not have the time or the duty to ask him to update his AC22 to the latest level. I therefore accumulate several versions of each AC.
Also when I click on this link in AC I see this page in my web browser :
It must be a server problem. After all, it's not really my problem but rather that of my clients. But what a shame that GS deleted its download archive page. For my part, I'm going to waste time and therefore production.
Christophe - FRANCE
Minh Nguyen
Hi Christophe,
Thank you for the question!
Are we talking about AC22 update or AC20 update? All AC22 (also AC21 and AC23) updates can be found under Support > Downloads > Updates for Archicad, then select the version and the language:
https://graphisoft.com/resources-and-support/downloads?localization=INT&type=AC&version=22
(there is a button to show More Updates, that will show all download links for the previous updates)
For previous updates for AC20, please follow this link: https://graphisoft.com/downloads/archicad/updates/AC20/AC20-6005to7001-ReleaseNotes (or it can be found with the Archive Downloads mentioned in your first post).
Please let me know if it helps!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Thanks a lot Minh !
The new interface must have confused me.
Everything is here ! Magnificent.
Christophe - FRANCE
Minh Nguyen
It also confuses me once in a while. Glad I could help!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
