Archicad 24 Update 3022 Released
Minh Nguyen
Dear all,
Yesterday we have made the first Archicad 24 Update 3022 available. We have created packages for the INT, USA, AUS, UKI, NZE, GER and AUT versions so far and they all passed our Quality Control.
The ā€œCheck for Updatesā€ feature will notify end users about the new version. We will keep testing the rest of the language versions and release them as they pass our Quality Control.
This update is relevant to the currently released versions of Archicad 24. All the upcoming Archicad 24 releases will contain the fixes of this update.
You may read the List of Improvements here, while the update installers are available on the Support > Downloads section of our website.
Should you have any questions or feedback, please let me know!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
21 REPLIES 21
Brett Brown
No one else finds this a little confusing? 3months and only 5 bugs fixed? Also, wheres all the promised added features that were publically stated at the launch that were going to be added at every Hotfix this year?
rjwilden
Don't forget to save your current work environment, as this release removes it and you wont get it back.
I don't recall having to do this before?? I lost my latest version, but did have a copy of an older one.
Hopefully all the bugs are fixed?
Richard Wilden Design. Ltd
Dunedin, New Zealand.
Imac 27" i9 3.6GHz; 32GB Ram Mac OS 11.3
Archicad V23:V24
rjwilden
Have just noted the the new version downloaded and installed today still shows "3008 NZE full"
Should it not read 3022. ???
Archicad V23:V24
Brett Brown
My Original was 3010 UKI SOLO, UKI is not updatable yet.
Minh Nguyen
Hi Richard,
Did you install the main version or the update? Here is my Archicad 24 NZE after updating:
The update can be downloaded at https://graphisoft.com/resources-and-support/downloads, under Updates for Archicad section. Please choose the correct language (NZE) and Archicad version (24) to get the link.
We are not aware of any missing working environment after the update. Could you elaborate about what exactly had happened?
Thank you very much!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Minh Nguyen
Dear Brett,
Unfortunately, the 3022 update for Archicad 24 is released for FULL version at the moment. We are still doing further testing for SOLO, therefore it is not available yet!
Thank you very much for your understanding!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
rjwilden
Minh
Normally when there is an update I go to "check for updates" but for some time I have been getting this message,
"RFA& RVY Geometry Exchange update", and not the current update status.
So I click on your link which took me to the correct site, but unfortunately I didn't scroll down and see the correct options, so clicked on Update current version and got a few problems. V 3022 is now installed. All good.
Not sure what I did, but my work environment options were gone and the "recent project's on start up" was also empty. All the Archicad work environment's where there.
Archicad V23:V24
Sounds like you re-installed the original Archicad program instead of just the update.
I think this would have deleted your user preferences leaving you with just the defaults.
Sounds like you have successfully updated now though.
DGSketcher
Legend
+1 I am sure (hope) a lot of work has been done on stability, but I was also expecting a significant release with updates to MEP, Param-o for MAC and BIMx?
