Minh Nguyen
Archicad 24 Update 3022 Released
Dear all,
Yesterday we have made the first Archicad 24 Update 3022 available. We have created packages for the INT, USA, AUS, UKI, NZE, GER and AUT versions so far and they all passed our Quality Control.
The “Check for Updates” feature will notify end users about the new version. We will keep testing the rest of the language versions and release them as they pass our Quality Control.
This update is relevant to the currently released versions of Archicad 24. All the upcoming Archicad 24 releases will contain the fixes of this update.
You may read the List of Improvements here, while the update installers are available on the Support > Downloads section of our website.
Should you have any questions or feedback, please let me know!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
21 Replies 21
Jeff Galbraith
I see. So as 'Preview versions' there are not fully supported versions? Kind of like a Beta release?
Jeff G
Archicad 27 USA (full), Macbook Pro (16-inch 2023, M3 MAX, 128 GB RAM)
Not really beta. They have been tested in-house as much as normal updates... but have not been coded and released for all of the dozens of localized markets yet. So, in the sense that they are pre-released for certain markets they are still being 'tested'... and the final release usually has a slightly higher version number. But, if you look at the huge number of fixes listed as addressed, it is typically well-worth installing. I've never seen a meaningful issue with these previews reported on the forums and have always installed them myself.
PS. Thanks for creating a forum signature 🙂
