2022-07-19 03:56 PM
i usually work on a 27" inch 4k display at 150% windows scaling and with 2D antialiasing turned off. Half the lines are thick and blurry.
Scaling at 100% is a bit better but you can still see the the problem.
No problem at all with Archicad 25.
2023-04-12 02:06 PM
What about the Fonts distortion when zoomed?
2023-04-17 08:15 AM
As Barry suggested, I sent an email to my local Archicad support (italy). No answer from them. This could be not a critical issue but the antialiasing is so bad i'm still on archicad 25 and i can't use version 26 i paid for. Right now the only solution for me could be to change my monitor to a unnecessary big and expensive 40" 4k or to get back to a old full hd monitor ( in 2023 ! ).
