Archicad Layer is turned OFF ??
Hi
While working in Archicad 12, i kept on getting the pop-up message below while trying to edit various entities (many editing options are not available anymore) . I finally noticed that the Archicad layer has somehow been turned off. I can't turn it back on in the layers manager or the attribute manager (or even overwrite the layer with another AAT file). How can i get this layer back on? Note: none of the work being executed is happening on the Archicad layer.
Thanks
Do you have AC12 latest hotfix?
Emerich
Unfortunately we've had that one here ourselves! It's a corrupt .pln.
Get in touch with your reseller and get them to restore the project!
We had it happen to the master copy of our template so it was pretty gnarly!
Graphisoft Aus got it repaired for us and it has been kicking along fine ever since!
Hope this helps
thanks for the info. unfortunately with deadlines looming, it's not an option and i'll have to find a work-around for this stage. but it's good to know the reseller can reset the file - i am going to find out what their lead-time is for this...
