2010-04-26 01:45 AM
2010-04-29 05:26 AM
what makes you think Adesk is sabotaging their IFC export?well simply because it is much easier to portrait IFC as an unreliable exchange format as opposed to proving that rvt format can actually cover all disciplines (which can not obviously). So it could be quite effective technique to discourage potential new users to not even bother with looking into IFC option.
2010-04-29 07:17 AM
2010-04-29 08:02 AM
The inherent problem with IFC is that it only translates 3D information. All of the 2D information like notes gets left behind. Therefore for the recipient to fully understand what is going on they need to consult a 2D copy of the drawings and mentally match that with the 3D information they have received.This is the fundamental misunderstanding of IFC exchange process. All information is in fact preserved within the element itself (not just geometrical properties but e.g. structural like bearing/non-bearing, all physical properties etc..) You just need to have the UI that filters and sorts all this information into some understandable format (e.g you can obtain annotation of particular element in a label-like form if your software allows it)
2010-04-29 03:18 PM
AFAIK Revit Structure does not do analysis so a structural engineer has to actually export this to some other analytical software by using (ironically) IFC perhaps?
2010-04-29 03:43 PM
2010-04-29 03:45 PM
2010-04-30 05:05 AM
AFAIK RISA do not read rvt files but use clever software (plugins) that control information exchange process.And this is the whole point... add-ons and plug-ins etc...
2010-04-30 09:23 AM
"...We are seeking 3 experienced CAD Technicians to join our London studio....
The ideal candidates will have;
A high level understanding of CAD software, particularly AutoCAD.
A minimum of 5 years of experience using ArchiCAD and AutoCAD..."
"We are currently seeking an Architect with three or more years experience to join our Sydney Studio on a short term contract basis.If you are interested in job in china you should be:
To be considered for the position you must be able to demonstrate that you posses the following attributes:
Demonstrated understanding of CAD software
Minimum of 3-5 years experience using ArchiCAD or AutoCAD
Ability to prioritise tasks & manage time effectively
Can do attitude and a willingness to learn
We are seeking applications from candidates who are available for an immediate start..."
2010-04-30 07:15 PM
2010-05-01 02:00 PM
