‎2009-02-24 08:52 PM
‎2009-02-24 09:06 PM
‎2009-02-24 09:19 PM
‎2009-02-24 11:08 PM
Archicad and Vectorworks are under the same owner. If they merge these programs then I am a lifelong customer.and you think that merging will do the trick... I wish if it was so simple but in reality merging those two could take years to complete (there is no point to contemplate on technical issues here).
Otherwise I am switching to Revit, and I have loved Archicad for 6 years now.well suit yourself but if you think that Revit is the Holy Grail that has it all... I suppose everyone learns best from their own mistakes.
‎2009-02-24 11:23 PM
‎2009-02-25 03:56 AM
‎2009-02-26 12:23 AM
ArchiCAD is a superior product to Vectorworks in many respects and areas; even the most die-hard Vectorworks users will acknowledge this.spot on. I think the non-official Vectorworks 'branding' as AutoCAD on Mac is actually true.
I think ultimately GS is going to have to develop these solutions to function natively and naturally in the ArchiCAD environment, but my only fear is that in order to achieve this, they would have to be forced to completely overhaul the engine - which they currently are obviously unwilling to do.Yes, IMHO this is the major problem at GS, having existing tools put on the free-form chassis is a very complex tasks (GDL coding, backward compatibility, UI reflecting the free form tool capabilities and you name it...)
‎2009-02-27 07:39 AM
‎2009-06-23 02:38 PM
frankyvero wrote:8. an intuitive to edit block object like sketchup has (and acad, and vectorworks,...): doubleclick - edit -close
Things that archicad needs:
1. Image or 2d line work as a filter option to be seen in 3d window.
2. 3d lines
3. NURBS MODELING (sweep, loft) not the <b>[censored]</b> profiler
4. Curvilinear walls that don't segment
5. 3d editing capabilities such as making a diagonal wall with out creating a roof to cut it to.
6. Manipulate Z axis of bottom mesh points.
7. A pen set which allows you designate color and weight independently
frankyvero wrote:but only when it comes to the 3D part... 2D is already better in vw
Vectorworks has all these abilities. But it lacks a whole lot more than Archicad.
‎2009-07-20 09:54 PM
Bricklyne wrote:Well I am a hardcore Vectorworks user (14 years) and I have to say that considering where the industry is now ArchiCad is superior - because it is a geniuine BIM application whereas Vertorworks is not, and will not be for some time, if ever. Having said that Vectorworks is absolutely superb at what it does. It also has two important advantages over ArchiCAD:
ArchiCAD's freeform modeling capabilities and shortfalls notwithstanding, ArchiCAD is a superior product to Vectorworks in many respects and areas; even the most die-hard Vectorworks users will acknowledge this ...
