Archicad Zoom 100% Actual Size (correct dpi)
After some search I found this registry entry
( HKEY_CURRENT_USER\Software\GRAPHISOFT\ArchiCAD-64\ArchiCAD-64 16.0.0 INT R1\DevSupport\Main Screen DPI ) , where you can insert your exact screen's DPI (96 for example) so that when you press 100% zoom, drawing appears correctly scaled.
(Windows7 x64, Archicad16 x64)
vistasp
Thank you Thodoris. That works well.
There should be a full list of registry keys in the wiki but for some reason, it's not accessible.
http://www.archicadwiki.com/RegistryKeys
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
Does this also work on AC15? Main Screen DPI does not appear on the DevSupport registry entry on mine.
Thanks.
