Heftor
Archiglazing Archicad 28 INT Full
Hello,
I’m trying to locate the official download source for the Archiglazing add-on, which was previously listed on Graphisoft’s add-ons page (link). However, the page no longer seems to host it.
Could anyone clarify:
  1. Is Archiglazing still available for newer versions of Archicad 28?
  2. If it’s discontinued, are there recommended alternatives for ceiling/roof glazing modeling?
Thank you for your help!
Operating system used: Windows 28.1.1
Setup info provided by author
11 Replies 11
mthd
Awesome !
AC8.1 - AC29 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia.
MinhNguyen
I was in the similar situation, looking for Archicad 28 ArchiGlazing addon. The one for GER/AUT will not work on INT (I tried). You'll need the INT version. It's clearly stated that this addon is no longer supported, so I'm not sure why GS decides to hide this one so well even for subscription clients. If you look hard enough (hint: don't look for the addon on AC28, but look for older ones. Also avoid suspicious websites - if it's too good to be true, stay away), you'll eventually find it for 28. I don't think it's ok for me to share it here though, so good luck googling 🙂
BIM Manager
DKO Architecture - HCMC
