‎2019-01-09 10:15 AM
‎2019-01-10 07:56 PM
‎2019-01-21 11:35 PM
‎2019-02-25 01:59 PM
‎2019-03-01 08:18 PM
‎2019-03-01 08:52 PM
‎2019-03-01 09:40 PM
‎2019-03-01 09:54 PM
‎2019-03-01 10:12 PM
KrisM wrote:I think that Matthew (welcome back) refers more to activating tools not necessarily selecting objects and having used both I have the opposite problem to your advantage. The inference corner delay you can fix by either editing your W/E so that the delay is 0 or by assigning a keyboard shortcut to activate it instantly (this is the one I prefer because then I have greater control). About the wait for view regeneration, AC views are not "live" and that is the reason for the delay, point to Revit.
As a contrary point of view, I find the amount of clicks in Revit to be less than Archicad. Also the selection of objects in Revit is much faster than AC. For example, if you place the cursor over a door in Rvt, you get instant selection as opposed to AC in which you have to find the magic spot to get selection.
Another slight difference, when drawing a line, wall etc. in Rvt, you get an inference (corner etc) instantly while in AC, you have to wait for a fraction of a second to get the inference. I initially found this quite frustrating but have learned to slow down a bit.
As far as accuracy goes, both programs have their hurdles to overcome and inaccuracy is principally user error.
another Moderator
‎2019-03-01 10:25 PM
ejrolon wrote:I don't do projects where it is an issue, but I thought that the "background processing" introduced in AC19 was pretty much supposed to take care of this.
