2016-08-11 06:04 PM
2016-08-11 11:33 PM
2016-08-12 02:25 AM
2016-08-12 11:17 AM
sinceV6 wrote:In fact I use direction dependent selection. It's quite unusable to use partial element selection when arcs are situated in complicated drawing on other elements.
Hi.
In the meantime, you could use either partial elements or direction dependent selection methods and arcs will get selected.
s2art wrote:True. Didn't noticed because I almost never turning on fills handles visibility. But since I just tried to turn it on I have to confirm that it's not right that you can't select fill until you include handles in selection frame.
I also think the same should be true for fills; when fill handles are used you have to include the handle in the selection area. This is dependant on fill handle visibility in On-Screen View Options too.
2016-08-12 05:13 PM
2016-08-18 01:45 PM
2016-08-18 11:59 PM
2016-08-19 03:29 AM
KatalinBorszeki wrote:Partial selection is working fine - even though it can be annoying when you select a centre point without realizing.
Hi All,
I have tried to reproduce this issue in ARCHICAD 20 with the latest build, and with the selection area method, the arc is selected even if the arc center is not selected. Are you still getting this problem? Thanks, k
2016-09-23 12:35 PM
2016-09-23 03:12 PM
