Area Calculation List Question
I guess the answer is propably is NO but i will ask in case i missed smthg.
When i use the area list creator i get a result that i can cut and past in a drawing.
Can i change the font size? I always get a result usable only in 1:50 scales that are too large to fit in the drawing. and when i resize the drawing the result is too mixed up.
If i could only set the text size.
thx
7 Replies 7
This doesn't answer your question, but I would use the interactive scheduler for area calcs and not the list schemes as the interface is cleaner IMHO. You can change your text size there, etc. and you have the ability to update the information that is placed on the plan, rather than just paste it. (Unfortunately, the update is a manual process.)
Karl
The area list calculator show graphically all the calculations required to calculate the area of a zone.
Can this be done with interactive scheduler?? I guess not
I don't follow you ... can you post a screenshot?
Karl
My version is in greek so i cannot tell you exacly how this is named in the english version but i post a sample capture from the output i get from area list calculation. The menu entry is just under the "construction simulation" entry in the caclulation menu.
Hmm. "construction simulation" is the last menu entry in the Calc menu in the US version (at least on my machine) ... so I'm wondering if what you're talking about isn't an add-on of some sort? I've never seen any output such as you show.
Karl
Is this stuff only in the Greek Version!!!!??
It is very very usefull not to be included in every version.
Petros Ioannou
It's a greek addon Karl! It takes a zone splits it to triangles-rectangles-etc, names each partition and writes down the calculation for each one and a sum.
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
