Auto Cornice Accessory for RAKING ceilings
i've enjoyed using a "design extra - slab accessory" to create automatic cornices on a regular FLAT ceiling by selecting the ceiling slab which represents the plasterboard ceiling lining.
Very productive.
Is there a similar quick method to add cornices to a RAKING ceiling? (rather than individually placing cornice objects with
roll angles etc and mitering as req'd - a little time consuming)
Note : I have used the roof tool to create the raking plasterboard
ceiling lining
Thanks for any input.
7 Replies 7
Djordje
You can look into sloping beams with custom profiles?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanks Djordje, i'll give it a go
Rick Thompson
There is an object that comes with the Smart Parts Trim library that I use all the time. You can choose from many predefined profiles (crown, etc) and set each ends miter and slope.. and of course the objects slope. The down side is you have to buy it, but I have gotten a lot of use from that library. I will attach a screen shot using it for rake moulding.
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
Rick Thompson
Here is a shot of the objects settings
Rick Thompson
Mac Sonoma AC 26
Nice one Rick.
Who makes this library and where do i source it?
Thanks again
Rick Thompson
http://www.ddgi.com/object_shop/d3sp-shop01.html
I use several of his libraries daily. I haven't figured out away to quantify the rake, which I have to do, but other than that I think they are great objects. I end up running rafters (which I need to do anyway) and place a little composite wall off to the side the length of a rafter that is linked to a property object to extract the quantities.
Rick Thompson
Mac Sonoma AC 26
