zone - ceiling accessories problem
zone stamp 19 seems to act not fully ordinarily with the ceiling accessories. maybe i am doing something wrong there so i will list some conclusions that i have encountered.
1. when zone height is zero you cannot create a ceiling.
2. however when you link the zone to the upper floor and try to create a ceiling for that specific zone the ceiling appears on the storey below.
is this the way it works? i thought the zone's upper limit would be the reference for the ceiling settings.
I would not consider No. 1 a bug. I suppose the Ceiling Accessory needs a Zone with some height, and this is why it doesn't work in that case.
Can you show a screenshot of No. 2?
Maybe the settings Dialog and also the result in 3D.
it seems somehow the project properties have gone delirious. when i tried with the default settings there was no problem. anyways, thanks for the answer.
