2008-07-25 07:33 PM - last edited on 2023-05-26 11:30 AM by Rubia Torres
2008-07-25 08:36 PM
rhendrickson wrote:No way to do it directly like Revit, but there are other ways to do it nearly as quickly. If modular, brick or block, set grid snap and insert by edge. But the one that I use most often is insert the window, then move it because the alignment line works like Revit in the move (or copy single or multiple) function. With keyboard commands its nearly as quick. I find that going thru the design from start to finish no matter how carefully I initially insert door and windows latter on I always have to adjust some of the locations after dimensioning just to simplify the field layout process.
My solution was to draw a line from the center of the window and the door across the West wall and use the line as a guideline, which I later deleted.
2008-07-25 08:59 PM
2008-07-26 01:44 AM
rhendrickson wrote:You can save a step by using the "Create Guide Line Segment" button (in the Control Box Palette). That said... I usually use Matthew's #1 method.
